E90 320i Engine vibrates after start-up
OYG
Hi fellow bros,
This happens to my 19 months old E90 320i recently. Usually after my ride has rested for overnight or after several hours when I fired up again, the engine vibrates and rpm appears to be low i.e. hovering around 500-600 rpm and fluctuating and behaved to be dying down---very irritating:furious: ! It might go away after I drive for some 10-15minutes. On some other occassions, it did not happen at all :confused:
My current mileage is 46k and will be due for 2nd service (covered under BSI) for another 3800km.
Anyone of you had experienced similar issue and any advice would be much apprecaited!
Re: E90 320i Engine vibrates after start-up
send back to agent.
alot of possibilities. might be the valvetronic + fuel pump + ecu like my old E90.
U are not alone..
Hi JasonLuan & MacGuyVeR,
Thanks bros, I will go back to PML. Cheers!
Hi OYG
Any latest update on the engine vibration thingy. Have been informed that engine vibration is has been commonly reported in E90:yikess:
megatnh;300313 said:
Hi OYG
Hi megatnh,
It appears to be ok now. Went back to PML 2 weeks ago and the SA said they may need to re-program the idling and it takes some time. Decided to do it during next oil service due next month. It also helps to warm up the engine before driving off. Cheers!
