Hey guys just wanted to share with all what I did during the morning, my volume buttons were getting unresponsive the past few months and i finally could not put up with it anymore. Feeling inspired (and a tad cheapo) I decided to try cleaning the contacts instead of shelling out for new buttons/contacts.
Step 1 is to disconnect the airbag
http://www.youtube.com/watch?v=aFlyBdNr7qI&hl=en-GB&gl=SG
A bit hard to see but basically theres a small hole at the bottom of the back of the steering wheel, I used a torx screwdriver pushed into it and felt around for a springy resistance, push HARD and the airbag should just come off easily.
Items needed for the job
Pictures below
CRC contact cleaner/maf cleaner
Philips head and Torx 25
Before
After
This is where the CRC contact cleaner comes into play see the 3 pin conectors at the back and the gold contacts on the rubber ? Spray liberally to clean the contacts. As for the Gold connectors on the PCB I sprayed the contact cleaner on a piece of cloth and wiped clean. Allow everything to dry for approx 2-3 mins before reassembling the whole setup tada you're done !!
Pictures below
Before
After
