e60 exhaust
botte_guy
Hi I'm running full stock exhaust system. I was thinking whether should I get a downpipe or midpipe for my 523.. Either from fk or jeep chee. The only reason I want to change either two of the pipes because I want the exhaust to be louder.. So any recommendation?
Re: e60 exhaust
Go to MAN exhaust and do a muffler delete. Most economical way of making your exhausts really loud.
Re: e60 exhaust
botte_guy;1077637 said:
Is muffle delete same as decatt?
Nope. Decat is remove the cat converter and put a straight pipe. Your o2 sensor cel might appear because of this, although there are ways to suppress it. Muffler delete is cut open your muffler box and chop off all the pipes inside. Its going to be really loud for sure. In fact louder than those aftermarket muffler.
Re: e60 exhaust
That means I would require another stock muffler just in case I got pulled over right?
Re: e60 exhaust
Yes, as long as u buy lta approved exhaust, you will need send it for inspection and get cert.
I just passed my 7th year inspection for me E60. Just show them your cert then no problem at all.
Re: e60 exhaust
sorry bro, but are you the first owner for the exos? or the previous owner transfer to you when you brought it?
Re: e60 exhaust
no need to transfer from person to person.
exhaust follows the car vrn. so must transfer from car to car.
Re: e60 exhaust
Bro , just want to ask you if I do the muffler delete at man motors like u suggest, when I go inspection can it be pass without them knowing it? Pls advise thanks
Re: e60 exhaust
Can pass. In an event cannot pass ask MAN itself to send it for you, they will settle everything.
Re: e60 exhaust
desmond_seow;1078313 said:
And are LTA approved exhausts really legit? STA inspections and all will be passable? Thanks!
LTA transcends STA.
STA & Vicom are commercial entities that are licensed by LTA to conduct inspections.
xs66lol
