e60 coolant leak!!
Calvin West
Hi guys just wna source out more info on coolant leaks. 2 days ago low coolant checklight appeared. At first I thought it was genuinely low coolant so I still drove the car till today when I wanted to refill my coolant tank I realized that there was a leakage. Pour water in straight away leak out from below till the ground. Recently just change water pump only, anything related? And also its weird that ive been driving for 2 days wo coolant and no overheating checklight or smoke from engine... (touchwood) pls advise.
Gam xia
Re: e60 coolant leak!!
Any white smoke coming out from the exhaust?
* time to change ///M5.....
Burn your gasket then you jialat.
Could be your water pump defective.
Gam xia
If water come straight out should be simple matter to trace source of leak - could be your coolant tank or radiator (?)
Wads the cost to replace?
Bring to site sponsor ...... No hoist hard to see from below ..... The coolant when leaking leaves obvious traces - the coolant is design that way.
Don't think it's the expansion tank though - if that cracks, it's over in minutes. Sounds like a slow leak, since it was depleted in days ......
Go to a site sponsor that has distilled water and g48 complaint coolant .....
last year my expansion tank tore open... everything out...
I replaced tank + water pump + flush radiator + new coolant
forgot costs .. shld be less than $800...
Wow which WS did u visit? I changed my waterpump flush radiator and new coolant about 600 $ not long ago.
using those "colored" coolant help to trace the leak, best to get a workshop to find the leak
normal problems encounter with cooling system is:
1. cap for reservoir tank kaput
2. reservoir tank spoil
3. oil exchanger for cooling of transmission kaput
#3 is most costly as the water can get mixed with the transmission fluid and become a lousy affair! damn difficult to flush it away and when water mixed with oil, it will spoil almost every rubber seal you can think of.
not $800 bro.. less than tt... I forgot costs liao.. last year bad luck... lol
