Jackiejb;1076528 said:Clear already
mt88;1076677 said:Most likely comp pressure/relief valve. Bring it to Tomika @ Ubi. They should be able to solve it for around $280
Calvin West;1076768 said:Facing the same issue with u bro air con slightly cold, under hot sun not cold anymore. Either your heater valve or compressor spoil. And yes compressor should be around 700, heater valve maybe 200+.
vwerke;1076774 said:I had the same problem with my Subaru Legacy previously and did a air con flush. There is a machine that can flush out all and later they refill back.
After that Air Con very cold.
Not too sure if can do the same to BMW.
