Re: E46 FL stock HU with PXA-H701 or Clarion D2, which sounds better?
Sir_Ducer;243973 said:
I thought that a clean HU source would tend to have better sound quality?
Probably at this stage, the 701 will have better staging and tweaking capabilities, but a clean HU will produce clean sound?
Hello Sir,
yes, you're definitely right. technically i can't dispute that... clean HU source will have better SQ, but that will be under ideal situation e.g. home audio, where staging is by default much more straight forward & predictable thus controllable.
In-car situation, all depends on taste. if u wanna 'good' sound, both hx-d2 and stock+701 combi will both have its respective trade-off, and under in-car installs, i think the overall effect, stock+701 gives a relatively 'better' overall effect of reproducing the natural recording sound (quality, seperation, depth and staging).
moreover, with our climate, exposure to heat deteriorates our speakers and amps and cables rather quickly, so the need for good processor can help to compensate for the constant deterioration.
but of course for listeners who don't mind (or prefer) full 'surround' effect, the seperation, depth and staging parts are probably irrelevant.
maybe just to dispel some doubts on stock e46 hu, it's an abv average set fm Alpine. amps and filters used internally are equivalent to that of the CD?-984? series... so actually mai-hiam-buay pai... stock sounds horrible mainly due to terribly lousy stock speakers... i believe those who've experimented... just changing the speakers as the 1st upgrade (no change of stock HU, no adding anything else, including cables) makes the biggest leap in quality... everything else after that is incremental, but not as dramatic.
just my 2 cents
