beem Well-Known Member May 14, 2007 #1 Hi Guys... Anybody has any idea where the e46 ABS relay is located? In the glove compartment where the fuse are or near where the DME is located?
C chickenbackside Well-Known Member Legendary 10 Years May 14, 2007 #2 Re: E46 ABS Relay Open your engine bay and stand facing it. It's on your top left corner of the engine bay, where you can see some steel pipes...
beem Well-Known Member May 14, 2007 #3 Re: E46 ABS Relay chickenbackside....that's where the ABS/ASC Control unit is...Relay is there also?
C chickenbackside Well-Known Member Legendary 10 Years May 14, 2007 #4 Re: E46 ABS Relay Sorry sorry! Wrong info! I was talking about the ABS/ASC control unit, not the relay. I know all the fuses are behind the glove box... Relay I dunno.
russo Well-Known Member May 17, 2007 #5 Re: E46 ABS Relay Why would you want to know where the relay is in the first place?
beem Well-Known Member May 18, 2007 #6 Re: E46 ABS Relay My ABS unit is not functioning. There's a few items i need to check before making sure the control unit is at fault. One of these items is the relay.
