E36 Brake Conversion
BMWme
Hi All,
I just bought a 325i E36 with an unknown front brakekit and I am thinking of changing it back to stock brakes or do you know whether I can use stock M3 brakes?
If I were to change the brakes, other than the rotor and pads, what else do I need for the changeover?
Thanks!
Re: E36 Brake Conversion
You can use original stock M brakes. Since you are not sure, just check the knuckle has not been modified. I think e46 brakes will work too
