Don't Bother Changing the Factory Filter.....
mr X
Most times it's just wasting money...
by Julian Edgar
We’ve been saying it for years but it’s a message that doesn’t seem to have widely got through. Nine times out of ten, dropping an aftermarket filter into the standard factory airbox is not going to get you any more power.
None.
Zilch.
Bugger-all.
Factory airfilters have excellent flow and they’ve also got filtration that matches the car manufacturer’s stringent criteria. Put a different filter in the box and not only will there be almost certainly no improvement in flow, there’ll also be an unknown decrease in filtering efficiency. That’s a pretty dumb combination to pay money for.
The way that you can easily assess the flow capability of the filter is to measure the pressure drop across it. No flowbench is required – just your normal car breathing in lots of air. (Which flows more than all but the hugest of flowbenches, anyway.) A sensitive pressure gauge with two ports that’s plumbed to either side of the filter will measure the difference in pressure at times of high flow. That difference in pressure shows how much flow restriction there is.
More pressure drop = worse flow.
Suitable pressure gauges for this application include the Dwyer Magnehelic gauges (they’re big but beautifully built and very accurate) or the smaller Dwyer Minihelic gauges (not so well built but still fine in this application).
The gauges can also be used to show the restriction of the whole intake system, just by plumbing the low pressure port to the intake before the throttle body (or turbo) and leaving the other port open to air.
In the case of the guinea pig car being used in this story – a 1988 Toyota Crown Supercharger - a 0-20 inches of water Minihelic gauge is mounted permanently on the dash. The car was bought and the gauge installed before any other changes were made to the standard car. In normal cruise, the gauge shows a pressure drop through the whole intake of 5 inches of water – very little.
At full-load, full revs, that rises to 20 inches of water, which is getting too high for max power development. (Any pressure drop will harm power, but usually getting the maximum intake pressure drop down to below 5 inches of water isn’t worth it for the amount of effort involved.)
Given that the car was bought secondhand, it was likely that the factory airfilter was dirty. And an inspection revealed that oh, boy was it ever filthy. In fact, the amount of dirt that came out when it was tapped on a surface was mind-boggling.
And just compare the dirty old filter and the clean new one...
So whack in the new filter and the total pressure drop through the intake will drop by a helluva lot, right? Like, maybe it will now be only 10 inches of water?
In went the new filter and onto the road went the car. And at maximum power the intake restriction remained exactly the same – 20 inches of water.... The brand spankers new clean filter made no difference to intake flow over the old, filthy filter. Y’see, that old filthy filter still flowed very well...
But aaah, you’re saying. What about without the factory filter in the box at all? Well, we did that test as well and if we were paid for imagining things, we might have seen a fractionally lower peak pressure drop – say, 19.5 inches of water...
To put it as simply as possible, there’s no problem with the flow of the factory filter – even when it’s dirty.
And we’ve seen the same story on everything from an Audi S4 to a Subaru Liberty RS to a Nissan Maxima V6 Turbo to a Commodore VL Turbo to a....
In nearly all cases it’s not the factory filter element which is causing the restriction. Instead, it’s likely to be the snorkel going into the airbox, or even the shape of the airbox itself.
Don’t start off by changing the filter; start off by altering the intake flow into the box.
AutoSpeed - Don't Bother Changing the Factory Filter
Re: Don't Bother Changing the Factory Filter.....
i disagree with the writer. i change the stock filter to hurricane drop-in and i can feel the airflow improves immediately (of coz with decrease in filtering efficiency).
while using stock filter, rev'ing to 4.5K to 5K rpm, the engine is choked and out of breath. you can hear it, you can feel it.
my comment applies to E90 320 (N46B20), at least. ABD posted previously that when he put a K&N drop-in, his 400Nm like drop to 200Nm ... kekeke
I too disagree. Perhaps K&N would like to provide their input? LOL.
do not suck by the facts. like ACS6, i'm a K&N whore.
BOOMZ
Unlike ACU, I'm a GruppeM whore. Waitaminute, it's K&N underneath....DOH!
who say changing factory filter wont make a diff....
just like stickers... it made the owner drive faster and sleep better at night...
psychological benefit is still benefit wor...
Out of curiosity on the type of air filter used by high performance car, in this case, a Lambo Gallardo, a google search revealed that the stock air filter is actually the paper type.
i m a BMW performance Air Intake whore...btw! So its factory filter whore too!
