does pss9 corner better than stock ?
Darth Vader
does pss9 corner better than stock suspension ?
koni fsd + eibach prokit was way better than stock,but no idea on pss9.
Re: does pss9 corner better than stock ?
Definitely yes.
kenntona;291699 said:
Definitely yes.
how much better ?
i corner faster with fsd+eibach.couldnt do the same speed in m-sport suspension.
people in e90 post said pss9 better than fsd+eibach.
really hope its true.
u'll need camber plates to top it off for even better handling...
i corner fastest with these.....u shud try them.
this one for cross country
this one if u wanna go downhill
this one if u wanna drive on pavements only.
Yes by a lot, compared to stock..
u shd also look at (incar) electronic damper and height adjustment suspensions..
u got balls to corner boh DV?
so DV... pss9 is only useful in corners....
u going track no need PSS9....
coz track no corner... only bends... sharp bends....
Yah loh.......muahahahaha.
So much power, relack lah......after 28th then install the rest of your parts, then U'll know the difference.
Not that this will be your one & only track day only mah......got more track days to come....then U'll need semi-slicks & 500bhp......
'The Great White'
i did 90 degree corner at traffic lights at 50 or 60 kph.
with fsd/koni it handles quite well.
so with h&r sway bars and pss 9 i can do 70 kph ?
u can do 700kph while asleep..... in your dreams... swee swee....
well u go n try n let us know.....
90 degree at 60??? how many lanes did you hog? use handbrake?
Siao! Ask this kinda qns sure kena humtum!!
So many factors to doing cornering....tires, road surface condition.....1 mistake means kerb or trees......
'The Great White'
:lol2: :lol2: :lol2: :lol2:
ToTO... U berry Farni!! I fell off my chair....
Corner so fast on normal roads, skid means jialet. Kerb or tree then bye bye liao
How you know fsd/koni cannot do 70km/h. You tried? :nehnehhh:
'The Great White'
i remember nutty prof also did 80km/h at newton circle after he installed H&R ARB. :)
kena left right centre....
Remember: SLOW IN, FAST OUT. FAST IN, NEVER COMES OUT!
If u wanna keep stock suspension, change H&R ARBs and its already much more confidence-inspiring when cornering.
