DIY : E90 320i Black Line Rear Lights Conversion
richlee7
Hi All,
Just got my Black Line Rear Lights in, and couldn't wait, so spent last night fixing up, and post here for anyone who might also wana DIY.
Time taken: 90minutes
BMW Part No: 63 21 0 406 678 (pix not posted to save space n time)
Contents:
- Boot assembly: 1 pc Left, 1 pc Right
- Main (body) assembly: 1 pc Left, 1 pc Right
Total : 4 pieces, each individually boxed, and packed into a large carton
Tools needed:
1) Standard (BMW ones in the toolbox is ok too) flat head screw driver.
2) Bolt socket 8mm
3) Angle driver (especially if you've got lotsa addtional wires fm other 'enhancements' running beneath your boot, else I dun think you'll need this)
Boot Assembly
Remove all plastic rivets holding boot inner carpet liner. Use the flat head screw driver. Use two screw drivers where rivets are 'harder' to take out.
Once liner is removed, you'll see the access to the light module.
Disconnect the cable first by pressing the 'catch' and pulling out the connector.
Once disconnected, It's only one bolt/screw to secure the piece. Loosen the bolt/screw using the bolt socket driver.
Remove the retainer (It actually 'slides' out), then the entire module
A gapping hole!
Prepare the Black Line Boot module by unscrewing and removing the retainer.
View attachment 22743 View attachment 22744
Insert the Black Line Boot module by slotting into the hole, but starting from the edge, as there are TWO catches that need to grab around the edge for a proper fit.
Once properly seated into the hole, assemble the beige coloured retainer, bolt it down, and re-connect the cable.
One side (I started with the Right side) of Boot module completed.
Do the same for the other side.
Body Module Assembly
Next, we move to the body module assembly portion (the larger piece attach to the main body)
View attachment 22747 View attachment 22748
For the Right (battery) side, turn the knob 90deg and pull out the carpet cover.
For the Left side, just pull out the cover out.
Once the cover is removed, the connections and mounting points (secured by 3 bolts) can easily be seen.
disconnect the cable, and unscrew the bolts with the bolt socket driver (8mm). If you need to use the 'angle driver' for easier and more convenient reach, use as necessary. Generally:
- to loosen: ANTI-CLOCKWISE
- to tighten: CLOCKWISE
Once the bolts are removed, the entire module can be removed quite easily, leaving a gapping hole!
Install the Black Line Body module into the hole, and loosely turn the bolts back in to secure the module.
NOTE: the holes are much larger than the bolt size, so allows for alignment.
Close boot to align the red/smoked line so that the Boot module and Body module are perfectly lined up. Then open up boot to tighten aligned modules.
Re-connect the cables.
Next, TEST the lights for:
1) No (lighting related) error message from the startup to engine idle
2) Lights are physically operating normally.
Once tested OK, cover back carpet/covers appropriately as you've disassembled area.
Sorry, no pix here.
Finally, peel off any protective sheets (you may recycle these to your Stock light modules)
Finished one side. Do the same for the other side in exactly the same way.
Once both sides are done, sit back and admire the diff it makes, visually.
Re: DIY : E90 320i Black Line Rear Lights Conversion
bumpz for the DIY....good work dude!!!
Good work.
Tks! Tks!
hope it's useful for the guys here who are modding/demodding...:)
Hi richlee7,
U again de DIY MAN!!! Nice, swee n easy understandg!!!
Tig@r;497029 said:
Hi richlee7,
yoz Tig@r, me still the lazy-to-go-workshop-unless-boomz... so far no boomz ;) ...
