__iceman__
Some notes to share with you guys, on my journey to audio nirvana. Warning - some pics may be disturbing as you see the nakedness of some internals, and some surgery. Hahahah
Some quirks, disadvantages, and advantages of the E46 as I discovered it.
Some facts, the completion took a few weeks, but 90% of the work was done within 4 days, of which I camped at installer's place just to make sure that they do things right, and for touchy stuff like proper soundproofing, I had no choice by to sit there and DIY with their heat gun.
Oooh... nice boot! Why don't we start getting some serious ICE in it! Bye bye original look!
Boot floor removed. Oooh... look at all that usable space inside!
Aw man... its really a nice german car. No flimsy plastic sheets, but a proper foam covering on the door. So solidly built. But TOO BAD. BYE BYE foam. Time to get some serious soundproofing in!
Oh shit! Where's the hole to mount my midbass driver??? So nicely sealed up? Original BMW speaker is mounted on the door board instead of metal frame. No no no no no WRONG!!!!
Bye bye metal! CUT CUT CUT. Heart pain, but bo pian. Here, look at the good workmanship from installer. There is a metal pillar directly behind the metal. Real tricky to cut, and not cut into the pillar. The speaker doesn't sit into the door itself, but rather this hole is for the speaker to drive into the door, so that the rest of the door becomes a proper sealed enclosure for the speaker.
So the speaker has to be 'floating' out of the door. Meaning very tricky and very THICK spacers need to be built.
With the spacer inserted in, and a proper seal.
With soundproofing on the MDF also!
Completed door with sound proofing. Total of 3 layers. One layer on outer door skin to prevent metal surface from flexing to the bass, and two layers (really stiff!) on the inner frame, carefully sealing up every hole, even some screw holes that are 2mm diameter.
