did you respray the whole bonnet?Azrielsc;421404 said:Yes. Same thing happened to me too. There was a dent on my bonnet. Too bad it was at the part where the metal reinforcement were. Ah Lye couldn't get it fixed so in the end, I had to get it puttied over and re-sprayed.
totoseow;423060 said:change car. the new R8 v10 is nice.
so what are you planning to do? i everyday look at the dent i heartache..pirate;424024 said:pai seh. I also victim today.
tatsit;424047 said:so what are you planning to do? i everyday look at the dent i heartache..![]()
ok.. thanks. how much do they charge?pirate;424088 said:tomorrow I asked them to come down and patch up. I can see the bone of the car loh. will post photos if its good.
its at the rear fender, at the bottom. the only way is to remove the covering to expose the suspension, but i've no idea how to do itstevenwu;426270 said:hi,
where is the dent ?
I got one just beside my door handle and it is impossible to get it push-out due to the lock assembly.
Look at the diy section, removed the whole lock handle myself and then get the guy at Capitol to correct it.....swee swee now..
In other word, what is the item that block the way and can this be removed from inside...if can then it can be done.
I always believe that maintaining the original paintwork is the BEST and will try not to respray if possible.
