Hi All,
After about a month or so after install the UUC ARB (used) I am hearing these creaking noises coming from the rear of the car. This is especially so as you are turning and going up a MSCP slopes and also when you are slowing going over speed bumps. Is this normal ?
Being an used item, I am wondering if the rear poly bushing are worn out and needs replacing. And am just wondering if after replacing them the creaking noise will go away, if they don't then...
Everything else is stock. Any bros here can give some insights here.
TIA
TIA
