foots;510126 said:when i listen carefully , whenever i make a left turn....i can hear wok wok wok sound . can anyone tell me wats wrong?
and another thing is.....the passenger door makes eee~...ook~ .....sound wen i go over road bumps...
This is because of the road condition.sharps;510133 said:over in msia, it happens to most of our CKD E90, mine as well
just tape it , then kaw tim
When I send my car in to PML for the creaking sound issue, was told by the CSA that this are known problems. He said that there are 2 ways of getting rid of the creaking sound, one by the Rubber protection spray, the other method is the Transparent Friction Tape. Was told that the Rubber protection spray is only temporary solution, sooner or later the creaking noise will be back especially under Singapore climate. I would rather go for the permanent solution, which is the Friction tape method.Solidgold;510430 said:I had the same problems with my new E89. At first i thought the retractable hardtop is the culprit. Top down no creaks. Top up all creaks show up.
I thought seow liao. Need to dismantle roof to tighten the bits in there to solve the prob. Luckily I tried winding down to window slightly to see if the
creaks are still there. Surprisingly, it all went away. So I suspect windows rubber seal problem liao. Search the Zpost and come across a BMW product
call Gummi-Plege. Some sort of Rubber Protection and care for car. So go to PML to buy one spray can.
After application, all creaks and knocks gone liao.. For $14, super worth it investment.
can order online from 3M or buy from hardware stores.privi;535712 said:anyones know where to get this friction tape other den pml? tks
doubt eng soon has it. u can try PML in the east if alexandra is too farzorro;535732 said:Wow, finally know where to buy the rubber protection spray...the rubbing sound when I wind down the window is getting on my nerve..
Does ES sell the Gummi-Pledge?..PML too far..
Slater;535735 said:doubt eng soon has it. u can try PML in the east if alexandra is too far
or u wan my half used can? i can sell uzorro;535739 said:PML Kampung Arang Parts Dept no longer operational and under renovation during my last vist in Feb...not sure its up now....
Slater;535745 said:or u wan my half used can? i can sell u
