Red_Bean_Bun
Hi All,
I maintain my own aircon (not referring to the ride in this case) - unhook the condenser off the wall, clear the pipes and everything else up. Found my inlet pipe from the compressor freezing over and thus the heat exchange is not happening - likely it is low on refrigerant.
The one thing I do not do is to climb out the window with a tank of freon, put on a safety harness and hang out the side of a high rise building to top up the r410 while monitoring the psi readings .......
So anyone use Coolserve before ? Are they any good ?
