Coilover and Sway Bar Queries
snowmanyee
Bros, any advice whether if coilover and sway bar legal here? Can pass inspection? Will installing both coilover and sway bar together redoned?? Would you spend that money to install them if your budget permits?? Any views and sharings?? I am novice on these. Thanks.
Re: Coilover and Sway Bar Queries
nerver heard off coilover & swaybar fail inspection
coilover = sure thing for me
swaybar = nice to have especially for a person who have high expectation on handling.
if budget permit = coilover + swaybar = as a package = one time installation for perfection :D
Very well said bro!!
U can tell him HID foggies are illegal......
:thumbsup:
'The Great White'
Hi snowmanyee,
it sure to pass LTA inspection..........
if budget allows, go for it......is a good mod ( power is nothing without good handling )
Any bros already with coilovers and swaybars??? Care to share your experience? Is the ride harsh and stiff on normal roads? Will the passengers complain or vomit after sit in your ride??
Hi Snowmanyee,
the ride is steam..............drove up KL....( passenger can sleep some more....)
* MTL
if you are very concern on comfort, then you should consider KW Street Comfort :thumbsup:
I've got both..........for the ARBs depends on the evenness of the road - as long as the hump or pothole hits both front or rear pair of wheels at the same time it feels ok. Else it starts to transfer that bumpiness to the other wheel if the hump or pothole hit only one side of the car's wheels.
According to some - ARBs are great for the long bending sweeps and to adjust your under/over steers - makes a lot of difference. Coilovers will take care of the simple short turn left / right body rolls.
Get those hollow ARBs - lighter. Those solid types weighs a ton ......
Noob question. Does the stock 320 come installed with ARB? Never really asked.
ARB, Anti Roll Bar?
it should have, it just that owner can still choose to upgrade to better after market ARB.....
yes. stock arb is 26.5mm (front) & 11mm (rear) for e90 318/320
ac323;604478 said:
ARB, Anti Roll Bar?
Thanks, then that's good enough for me.
Stock is definitely good enough..............
Even Hyundai Verna has ARB, how can BMW don't have it?
Sure or not?
Dun bluff lah......u should ask him to change instead of saying stock is good enuff.....muahahahahaha
'The Great White'
wilman2772;604548 said:
Sure or not?
'The Great White'
Lolz......................i think also depends on his driving style but am sure after the coil logically he should upgrade the ARB................
MTL
Thanks bro for all the sharings. BMW sure has ARB as BMW's handling is second to none (stock vs stock comparison). An even harder decision to make now after starting this thread. :)
Profile yourself - are you the type who enjoy a comfortable ride (for instance, prefer 18" over 19") or prefer a harsher ride but slightly better handling....... no point modding if you could not appreciate the change in drive dynamics.......
