Check engine light-help....
Ah_Bock
Hi guys,
My car check engine light came out and the car couldn't pick up speed....I think it went into safe/limp mode....what could be the problem???
Re: Check engine light-help....
Check your gearbox bro.
Hi Bock, same thing happened to me a fortnight ago. Check engine light came on, checked with the forum gurus and found out that it could mean anything from as small as a faulty spark plug, to more serious engine problems. Power loss was rather insignificant but decided to check with the workshop anyway. Went for the check and the problem was a faulty valvetronic motor. Got quotes from various workshops and this is where Boss Motorsports stood out. Rather than quoting directly, they asked me to go down for a check to see if the problem is really the valvetronic motor. To cut the long story short, Boss ran some checks, did some tuning and advised that there wasn't any need to change the motor. What would originally have cost 900 bucks was reduced significantly to less than 100 bucks. Car is now running as per normal.
Bock, I'd advise that you call up Boss and set an appointment for a check to see what's wrong. Good luck buddy. Cheers, Sam
Car is at boss already......they told me my valvetronic motor fail too.....
Okay. By far from the quotations that I've gathered, Boss has been the most reasonable. Look on the bright side, at least the problem is rectified and you'll have the car for the weekend. Have a good weekend ahead buddy. Cheers, Sam
Hi Ah Bock,
is your ride Grey (E46 Sedan)? saw it at BOSS......................yesterday
Ah_Bock;657494 said:
Yup yup....that's my ride.....
ok, swee...........
* nice matching rims too
Thanks....2days ago tow in the car to repair fuel pump...expansion tank, water hoses etc....collected car yesterday then ard 3am cel came out....then got to limp slowly back to boss.....
Haha 2 trips to the workshop in 3 days......
