changing engine oil
melo
Hi guys
Am hoping some of you might be able to help me with a question (or two).
I'm aware that quite a few people here get their car's engine oil changed between services at PML. Is there any problem switching between eg: Mobil and Castrol (which I believe, PML uses?) as long as you stay at the same weight oil?
Also, the manual recommends 0w oil? Is there a reason we should use a 5w oil instead? I'm a little concerned if this would have any effect on the engine when it heads into PML and gets a new batch of 0w oil.
Thanks
Re: changing engine oil
Have been on Mobil1 SuperSync in between PML's Castrol.
No issues at all.
Mine's a 2.0L Valvetronic.
6-potter owners,
Please comment....
Also been alternating between PML's Castrol Longlife, and Mobil1 SuperSyn in between, stayed with recommendation of 0W-30. Have also tried Torco SR. Very smooth too.
i've been on Mobil 1 too..5w50 i think..am thinking of trying out either Royal Purple or Torco...perhaps in a thinner weight...0W40?.. what do u guys reckon? i'm hesitant to try 30w oils..might be too thin for my ancient engine! ('92 M40 E36!)..thanx for any advice!..
btw.. what oil should i use for the final drive pls? where s a good place to procure it too?..thanx a bunch!..:)
cheers!
I was advised today by a workshop mechanic to change my engine oil when the dashboard reads 12500 to next service.
He said normally 25000 is recommended by BMW but Singapore being a tropical country, it is recommended to change twice in 25k.
Is it true? Pls advise
Hrm.....depends on your preference lar. If you sayang your Beemer more,then change engine oil more often lor. At the moment, I am changing the engine oil every 3k-4k km. Might have to decrease the frequency though since petrol prices and slowly but surely inching towards the heavens. Sigh.
No issues at all.
6-potter owners,
Please comment....
0w-40 Mobil 1 SuperSync Gold in 6potters...very smooth engine :)
I m using it
No prob in switching. I've been running on OW-40 Mobil 1 Supersync Gold before switching to Torco & for me I'll throw oil between 5 to 8k km.
Hes not wrong by the books. IMO, 10k km is abt right to change, no point maxing it out. Healtier for the engine & better response after.
Hey AC Boy...you are David low's friend right...we played golf once at Kranji.
Thanks for your comments.
Tats me! We play every week, regularly we've 2 flts. Do join us & let me know if you need help on the oil change. Cheers!
So where is the best place (or at least highly recommended) to do any engine oil change? BVO? And how much would it cost (oil + labour) assuming using Mobil one? For a 325Ci.
i did mine at autobacs. $10 for labour because i brought my own oil, think its less if you buy oil from them. other places i called quoted around the region of $30.
Engine oil change at BVO labour is $15 or $20 with changing the filter... done on the spot :)
me using the torco 10-40 now...smooth...but a freind urging me to dry the motul double ester...says gtee nirvana...anyone tried?
Would anyone be able to tell me what is the recommended engine oil grade for my 318i's valvetronic engine? Sorry if this is obvious to people, but I could not find any reference to this in the user manual. Wld like to change engine oil in between visits to PML. Thanks.
BMW Long Life 0W-40 ... think BMW recommends Castrol RS 0W-40 ...
I just changed to Mobil 5W-50 last weekend. I used Mobil 0W-40 and PML Castrol 5W-50 in my last 2 oil changes.. To me.. MObil 5W-50 is shiok...
FYI - I also changed plugs so maybe that's why my 320 is pulling away nicely when I rev it... JMHO :)
Wait till you try Torco Racing :sneaky:
