Re: Changing ATF
Chewy said:
hello guys, been following the forum for a while......saw topics on Transmission, so just a question for your advice and enlightenment.
DO you guys experience delayed gear change when driving of in the morning w/o warm up?
Not sure if this is normal for e36? thank you.
It may be that the oil within the transmission has not warned up and therefore the oil is thicker and hence slower in reaction.
If upon warm up, the car beahve normally, then it should be ok but beaing in mind that it is also a sign of a aging torque convertor. My former E36 was like that and then at warm up, it will take about 3 second before it goes in to reverse gear. U hate it when u r parking the car with a few car waiting to pass u.
The reason is that over time, the oil will get thicker and will help to balance and irregularity within the clutch plate in the tranny. By draining out all the oil at this stage, u will affect the residual pressure within the gearbox which may cause the plates to run out of place, causing a direct failure.
There is nothing u can do about it since changing oil at this stage may just kill it immediately. The good thing to know is that there are a lot of re-conditioned out there and even the price of the re-manufactured gearbox from factory has come down quite a fair bit.
There had been a few cases of such and PML has taken a stance to avoid changing tranny oil unless it's by owner request and consequence made known.
And by the way, the oil is a lifetime oil and definition of lifetime is not equal to our COE. The lifespan of the gearbox is only around 130k, anythjing more, it's bonus
