Car vibrates when stationary after driving for at least 20 mins
panda8
From cold start, no vibration. But after driving for about at least 20 mins the vibrations will come on n is v noticeable like whole car shaking when stationary or a v low speed.
If I were to turn off the engine n restart again the vibration will be gone... But will come back again after 20+ mins... Any seniors care to give their thoughts on the???
Just got the car for 2 weeks... 8 yo 523i
Re: Car vibrates when stationary after driving for at least 20 mins
Check the error codes in a workshop to avoid the guess work.
No error code flash on console display... Have set up appt on wed afternoon to check it out....
I have been experiencing this for a while.
PML said nothing wrong. But I thought i was sitting in a sampan.
And this happens when the engine is cold. Once warmed up, vibration gone.
No fault code whatsoever. So i just leave till the car goes into limp mode.
Whenever PML says it's ok ...... That's after they clear the codes. So many time I see all kinds of codes pop up when I look at the diagnostics of some bros' ride ....... Especially when the codes are those ambiguous type.
That may happen.
But so far, car runs well. So, I didn;t really use the buddha palm method.
Spark plugs well worn out... Did a change w a set of new spark plugs n solved the vibration...
banca300net
