Car key kena soaked in
T6
Made a boo boo and left my spare BMW car key in my shorts and wifey soaked it in the washing machine for an hr before it was found out. Not sure how waterproof the seal of the car key is. Yet to test if it is still working. Even if it can lock/unlock the car, hesitant to slot it into ignition without knowing if there are repercussions as a number of data wld be stored in the car key. So not sure if it will screw up the electronics.
I am tempted to send the key to PML for a once-over. Any of u had such an experience?
Re: Car key kena soaked in
my suggestion : remove battery immediately if can be done, if is 100% dry up & battery change shld be ok.
if not, dry up before u send for warranty claims haha, self-inflicted not count right?
:lol2: hee hee like what we always do to our mobile phone.
u such a smart boy ! did it twice kekekekekeke................
hmm.
another way is to change car. :p
Happened to me before (keys of a loan-er 5er), dropping keys into pool, opened up casing to find that it's rather waterproof so crisis over.
In your case, follow Bro's instructions. Open it up and remove battery. Let it dry up completely, and I do mean completely, then assemble back for test. Should be fine.
Else, change car. Wilman's got an import E93 M3 for sale. LOL.
the new keys on E9x models all no need to change battery for life. that's what I was told. the key charged during it was insert into the key hole. so i'm doubt the key can be taken apart to dry the internal parts.
I doubt that is true, Acu.
I opened up my key and checked the samsung batt on it and compared it with the specs online and found out that it is non-rechargable. After speaking with my CSA, he too told me that its non-rechargable. However, the batt will last about 2yrs, depending on usage.
wow the feedback damn solid.. haha look like change car is the better chioce !
wah... SAM, really ar... hmmmm....
I'll check with them again. thanks for the info.
If I was you.... I would change my keys, car, washing machine and most importantly WIFE!!!!!! kekekeke
Really ah, my CSA Jeffrey Vasaloo also said its rechargable.
A replacement key cost ard 50 bucks...
Had a loaner car once, fiddling with the key, and mine dropped into the slots down the lift shaft at ESPN Lorong Chuan.
3-series and 5-series different? I only know that my E92 FOB is definitely NOT rechargable. :)
if you wish to take the risk and try it out, i'd suggest you open up the key and put it under the hair dryer for five to ten minutes before trying...
normally, if the buttons were not depressed when it was submerged, it should be fine... but if you have a built-in secure-chip, then well, it's tough luck - but worth a try anyway before forking out $50!!
I think the key is rechargeable, at least on the e90. In fact I was advised to use the spare key once in a while during long trips up North to charge it. This info was fed to me during collection of my car on Day 1.
I will confirm once and for all when I send my car in for servicing soon and have the spare key checked.
Tks for all the feedback guys.
Re: Car key kena soaked in water
T6;311924 said:
Made a boo boo and ...
read somewhere that if u inadvertently drop an electronic component (like a mobile phone) into water, there's apparently a way out ...
the suggestion is to bury it in a bowl of uncooked rice overnight. apparently the rice soaks up all the moisture.
dunno if it works tho ... but no harm in trying ... nothing to lose ...
:D
I think the key is not rechargeable if you have comfort access. Without comfort access,its rechargeable.
:D
i think buy hippo better and faster.
