Camshaft M54 Engines
BlackStealth
Legendary 10 Years
Hi all,
Just got my new dose of medicine today. Hope I will feel some butt power.
Technik Engineering Camshafts :
Applicable for all M54 and M52TU blocks.
Alignment markings are shaved off..hmmm...going to be a pretty tough job to align it.
Re: Camshaft M54 Engines
nice... what's the cam profile and how much did it cost?
Not you align mah, dun worry just seat at the kopi shop and relax
Oh No..not again..its gonna be very hard now to ever keep up with u !! even if i s/c ...fark !!!
but man that should be good. when u getting it installed ??
Jason Hello! You 1st time go workshop ah? Have you ever seen me sitting in the kopi shop lim kopi while Ah wee is working on my car? I always work with him one you know....
:p
Jeremy....Dont say like that la... I dont have the lines, remember?
wah.. i admire u man.. going all out!! what's next?
p/s: where u got ur diff? got web links?
No, the torque will be gained on low, mid and high.
..and it also depends on which application profile of cams you using. I believe for most general applications, high end torque is the sole objective.
Markings or keyways which can easily be 5 degrees off are only for econo production slop or to set closer starting points. Working actual phase via lobe centerlines only takes an extra 5 minutes if you have a degree wheel and two dial indicators. All are cheap.
Yes, luckily my dear mechanic has the tools and knows what he is doing.... couple of shots just to add excitement to this thread.
Quite a tedious job as all those cams brackets tighten by torque specific nuts are needed to be removed. Look like operation on the surgical bed. Having some difficulties in the alignment process...
Check out those TANK CHAINS for the double vanos man! Sure beats the conventional rubber belts.
..............on the side note, check out who I saw today trying to add a little "something" to his ride!
SPYSHOT! BUSTED!!!
wah...monster mod... are you planning to dyno your ride to see the % gains?
wah nice pics man Des. I guess I need to buy you navy blue overalls for you when you work with Ah Wee
BlackStealth said:
Hi all,
Bro, your spec for your camshaft not for "normal" engine one leh hehe....
Usually the intake should be higher than the exhaust side. But i know what application this is for la... power !!! those in the states claim to have good gains :)
Usually the intake should be higher than the exhaust side. But i don know what application this is for la... power !!! those in the states claim to have good gains :)
Yup!
U R so rite bro! It's not for 'normal' engine........his car is hybrid, half petrol half hydrogen fuel cells.....:lol2:
'The Great White'
Never Dynoed my car for like the longest time...hoping to see some significant gains.! (b/w 20-30Bhp) Would you like me to post my dyno chart? :)
Wah, i know i am always there la, now you want to make me an employee?
Not many people will "understand" when I show them the profile of 248/256. You saw through the lines.... I had to do this to compensate for my lousy sepang lines.
wilman2772 said:
Yup!
'The Great White'
YOu talking about my new Honda Fit?
well, didn't know that you would want to post the dyno, that's why i asked for percentage gains only... hehe, but the graph would be good
