Breyton Rims - Spacer
steamy-stream
Breyton Rims:
Is it true that for 5,6,7 series needs a special Breyton spacer to be able to fit?
Or is the shop guy trying to pull a fast one!!!!!
Reply please Thanks!
Re: Breyton Rims - Spacer
steamy-stream;466526 said:
Breyton Rims:
am planning to change to breytons as well. told him it was a E90, he said no spacers needed. not sure bout 5, 6 and 7 series.
steamy-stream;466541 said:
E90 is all ok! Only the rest of the series!
best is to call up a few more shops and check if the responses are the same!
My understanding now is that Breyton manufactures their wheels to fit the 3 series. All other series will need a spacer. It's a smart way to reduce cost and without having to manufacturer different wheels for different car series.
Dude
Unless offset of rims is not meant for your car or u larping in BBK, u will then need spacers to clear. Talking abt the tire shop pulling a fast one, hmm...don't tell me is some appointed agent...
Another way to prove if he is honest or not, if he is recommending Breyton spacers, see how much he quote you for a new set, you can tell from there.
Good luck
Yes, you will need spacers for Breyton as they are now manufactured free-sized. It will fit the 3er fine, but 5, 6, 7 will need spacers. More cost effective for both Breyton and their dealers this way as they won't need to stock that many wheels. Insist on hub-centric spacers like eibach etc and you'll be fine.
not all model breyton wheels need spacer.
to confirm just check breyton site see got any clues?
using spacer like this is not some thing new,longtime ago (10 yrs)brand like AC(some model) oredi used spacer for the 5/6/7 series, only thing is many owner dont know:shakemyb:. is notihng wrong to use spacer (good brand) if you need to have the offset you want or need.
only thing to make sure is the screw/bolts are long eough/hub centric and does not have any vibration after putting on :huhhuh:
to buy a good quility product is easy to konw what brand to get.
But to find a good quality workmanship workshop is the problem and sometime you were hear the excuse they said is Like that one:shoot:
Thanks for the replies,......
Really helpful.... the spacers are from Breyton (That is what it says on the box)
I think you guys are right....
Breyton are saving on cost.... btw it is now made in China I heard! Damn!
is fine for the production place.at least this guys are honest enough to tell you
so long is the original is Fine.
that is why the $ is so competitive:dance:
if you worry about are they original ?simply ask for official invoice :shakemyb:
Hi robertan,
no need spacer for my E89 (Z4) as is the same off set as 3 series, so for 5, 6 and 7 maybe you will need and also depending on your BBK (if you have BBK).
Can't wait for my car to be out!.....
By this friday.... it will have a body kit and 20" Breyton's...
Hi steamy-steam,
congras man...........
which series of Breyton you bought? Race CS or Race GT or Race GTS?
Thanks for all the replies! Very helpful.....
So here's the story!
This was done 3 hrs ago!
Line up for my inspection!
OK! Carry on .... install!
Check out the spinning action!
All done up~!
Breyton GTS - 20"
Very happy! ..... :dance:
Hi Steamy-stream,
thumbs up man!!!
Good stuff. Didn't expect the GTS wheels to be this nice. Now when will we see the bodykit?
