Brake Upgrade - what it means for me
centurion
Seen a spate of brake upgrade post recently. After having the fortune to hang around with engineers like my dad and some I met on this board, and a ravenous appetite I have to read everything about cars, and spending my own money on brakes on my previous cars and one of my current cars, let me share some observations.
1) Upgrade brakes rarely feel as good as stock - OEMs spend a lot of time tuning the brake subsystem for good balance in smoothness, stopping performance, safety, feel, modulation ... the smoothness, feel and modulation part affects the way we feel the brakes as we press the stop pedal. A lot of it gotta do with matching the master brake cylinder with the caliper piston size, and tuning the electronic brake distribution parameters to match the parameters of the front and rear brake system. If your brakes have too many pistons or too big pistons for your master brake cylinder, you will lose modulation and feel. The car will like STOP suddenly or don't stop. 1 or 0 binary behaviour.
2) Upgrade brakes do not necessarily brake shorter distance as stock if the brakes are not overheated - in normal highway driving, even NSH driving, you rarely overheat the brakes if you don't do extremely spirited accelerate-brake sequences like 20 times in 5 minutes. If you are the type who drives below 170km/h you need to brake slightly at most once every 5 minutes. When you brake hard enough, the caliper sure as hell can grab your rotor hard enough to lock your brakes and tyres - you can always invoke ABS on your stock brakes, right? Stopping distance of a car is directly proportional to tyre friction, NOT the size of your brakes. What's worse for the case of upgraded brakes, is that your electronic brake force distribution system in every performance car, may not be tuned to your big new brakes. EBD does a lot to decrease braking distances by feeding brakeforce to the rear once the front traction is finished. But it works within parameters, anytime it is out of parameter it will revert to limp mode behaviour. Meaning, longer brake distances. An example is the installation of the intensely rear biased GT3 braking system to a 987-series car with a mid engine. The rear will lock almost immediately on hard braking and the EBD will not respond properly, despite heroic efforts this can't be remedied.
3) Upgrade brakes are good for consistency under extreme stress - if you go to track, a BBK will be better than stock, simply because if you do lap after lap the bigger brakes can soak more heat and prevent your brake fluid from boiling so quickly. If you go to track upgrade brakes AND pads are definitely a consideration.
4) You lose the brakewear sensor with upgrade brakes - if you use upgrade brakes it is almost definite that you lose the brake pad wear sensor. Which is OK if you are the type who checks the damn thing every day, but if you're note, one day you will just experience the ugly screech of metal to metal interface destroying your rotors.
5) Insurance issues - if one has a bad accident, with huge claims, with brake failure being a factor, insurance companies pull out all stops.
6) Replacement costs - I don't kid myself. Even on my untrackable car, I would need a rotor change every 1.5 to 2 years for comfortable braking. Basically a rotor change every time I change a pad. Stock rotors are not breathtakingly expensive, but most BBKs are. Unless you can change to a BBK from a higher version of your car (eg. using 335 brakes on a 320) non-OE parts are always more expensive than OE parts. For both rotors and pads. Recently the aftermarket BBK rotor on my MPV cost 2X the price of the stock brake rotor of a Porsche.
7) Strange tyre and pad wear patterns - this is about EBD again. If you have too much mechanical front brake bias, most of the car stopping is done by the front pads. Depending on the way your EBD is tuned, it will also usually bias the front brakes to the front, electronically (so you don't spin the car). There are cases of people who upgraded the front brakes, that the rear brakes do not get used AT ALL. It's always the front taking the load, and tyre and pad wear, also rotors, on the front gets stupid high, and the rear tyres don't get used at all, especially in a all-street driving scenario.
So, before you go out to get that sexy bbk, this is my contribution to keeping money in your pocket, and perhaps, to increase safety.
The reason why I dunked money on a BBK on my MPV bigger than my performance car, is because the MPV does mainly long distance driving and hillclimbs (my son's favourite destination is on a hill). I warped 2 sets of stock rotors in 6 months on the fronts before I needed to take the BBK on. The reason for warpage was because the brakes were definitely underspec-ed for a MPV going at 180-200km/h - I could not even sustain more than 2 hard brakes every 5 minutes before heat above the design parameters of the stock rotor will cause uneven rotor expansion will start to judder the front brakes.
Re: Brake Upgrade - what it means for me
Good points there Mike. Some things to think about before plonking ur hard earned money on these BBK. :)
digress a bit - someone pls explain why the guys in munich insist on using single-pot sliding calipers on performance machines as stock brakes.
i know that these are good enough for normal street driving, but most M and twin-turbo drivers usually engage in passionate and spirited driving (c'mon guys, who are you trying to kid, kekeke?)
and despite coming up with 'performance' range brakes (OEM brembo), they have changed the configuration such that some 135 drivers have experienced brake failure on the track.
my point is, is the ultimate driving machine catering so much to the masses that they've lost sight of their roots? e.g. i mean it's ok to have the sliding calipers on the 4 & even 6 pots, but on cars with more than 300hp?
pardon my ignorance if this is a stupid question...
there are many implementations lah, but sliding calipers have really less problem and performance is not so big compromise. Also, because of single piston, modulation may be better than multipiston both side piston configurations.
And the BMW M3 I heard one super spirited driver go 8 laps with no brake fade on stock brakes and pads, in searing 40C ambient temp of Sepang's brown tropical hell. Nothing bad about the M car stock brake man.
so i guess they really know what they are doing?
A car manufacturer, even with all its inefficiencies, has 1000 brains which can work like 100 smart people at the very least. Better than a brake manufacturer who has 3 very smart people who can work like 6, with conflicts of interest and up against a car manufacturer who has more time to test, try and much more resources and more options, and against much more challenging conditions and more and more pushed to extract the maximum out of their cars today.
It is indeed rare for any upgrade to work better than stock brakes off the track, from an overall perspective.
Which problems are unique to fixed caliper brakes? Why is modulation possibly better with sliding calipers?
Whoah..extreme doubts on this man.. mainly on the pad front. Or maybe BMW speced some really good compounds that don't make noise, and then high quality rotors to deal with those compounds. Anyone have M3 brake duct details?
sliding calipers have piston on one side, less parts, self adjusting, less plumbing - by definition less components less failure. Easier to modulate because single big piston is cheaper and easier to build in precision and quality than multiple pistons.
I didn't drive the M3 for long periods on track, no comment on the veracity of my hearsay. But I trust the hearsay though.
wilman2772;390191 said:
Where are you man?????
Wat a waste you can't go for today's track man.....perfect weather, super fun man!!
The M3 DCT is super duper fabulous to drive man!!!!
Drove 8 laps in Omar's M3 DCT......AMAZING!!!!
Shifting is so smooth & fast......makes me gian also......but $ no enuf.....dam......
'The Great White'
I was with Wilman when he drove my car. After 6 laps got a little spongy so we back off and drove normally. 8 laps in total. 6 relatively hard laps and 2 normal laps with earlier braking. Total 8 laps. Just to highlight that the M3 DOES NOT have any brake ducts and I am pretty amazed with the performance of it on track and the sustainability. Hell I might just swap with better track pads the next time round for track. I already changed my brake lines and Brake oil btw so it may not be as good as comparison at a bone stock m3. But in any case, its still a good comparison.
omar, in comparison with the alcons on your previous ride? any perceptible difference?
Your MPV's is not well researched for high speed braking? Or your driving habits? 2 stock rotors in 6 months is no joke.
The under-specs reasoning should be applied to modded car. Take a charged M54 block which increases horse figures by 100. No way the stock brakes could be sufficient......
I think specialisation is ignored here. If this is true, then practically all aftermarket parts will suffer from this syndrome relative to OEM.
Depends on how the car is modified and how the driver push it.
Would love to hear from E46 M3's with or without brake upgrades for placebo effect.
the best upgrade a stock braking system can have .. is:
brake duct
brake fluid
brake pads
the biggest problem faced for us lesser mortals who installed BBK is brake bias ... other than dedicated track cars, i have not seen anyone installing brake bias bar .. and doing testing in that area
true and not true.
upgrade brakes rarely feel as good as stock. most oem parts take into consideration of the general public and cost. if your master cylinder is too small for your bbk, it will never work.
upgrade brakes not necessary brake shorter distances. if everything being equal, a bigger rotor and bake pad will definitely stop the car in a shorter distance--law of physics
some bbk do come with brake sensor and as long as you mod your car, the insurance has every right to pull the stop, that including going track.
last a car manufacture is a car manufacture, a brake specialist is a brake specialist. and why do they call it oem? in today competitive enviroment almost everything is outsource.
Here are my very key thoughts.
Always know what you are changing too. Trial and error can be costly but at least if you are changing to something made specific for the car, your car will be fine. Don’t forget Murphy’s Laws.
Upgrading brakes can take a few grades:
Grade 1 - Changing of rotors and/or pads
Grade 2 - Grade 1 plus replacing the rubber brake hose with ss braided lines plus higher temp brake fluid
Grade 3- Full on Big Brake Kit
Responding to Cent's points:
1.Agree that some brake upgrades don’t feel as good as stock's in terms of feel. This is obviously only applicable if you have done a full on brake upgraded ( Grade3 ).
While some cars brakes may not feel nice/smooth etc in terms of stock feel , one can look to find a solution to remedy this. So we have to speak from both point of view here.
I give you an eg. I hate the brake feel of Gallardo. It's all or nothing and it's hard. Can't really modulate, can't trail. I was shocked to experience it when I test drove the LP560. The boss of Eurosport said to me this is the problem with Lambo brakes, they are nowhere as nice in terms of feel as the Porkys but u will get used to it.
Sure, but I was still turned off.
2. Agree with your point no.2
The person who upgraded the 987 brakes to GT3 OEM brakes either :
- Had no clue that the GT3 brakes are indeed very rear biased OR
- He got a good deal out of it and tried to make use plus it looks good and it fits well
This could well be a trial and error case but in any case, a risk to be taken. Like I said above, know your mods.
3. That is the whole idea of having a full-on BBK set up. Again, choose wisely. Understand the compatibility. From my personal opinion, those who go to track on regular basis, say every 2mths or so per year. The minimum you should do is to upgrade to Grade 2 ( + invest in a set of track pads ). I went through this route before in my Z4 and the brakes worked brilliantly.
4. Well....this isn’t necessarily a difficult thing to do. After all, if you intend to do some hard driving, you should know how thick your brake pads are before you go anyway. The sensors can’t tell you how much left anyway. It’s a common advice given.
5. It’s always an area of weakness and we all know it. The same thing can be said bout many other things. Suspension change to after market coupled with bad wheel alignment that result in accident will give rise to similar case.
6. Not quite a fair comparison. A BBK on your MPV is an after market upgrade. Your stock rotor in your car remains a stock item. Try to upgrade your cayman’s stock rotor to say after market Alcon or Brembo discs with aluminum hat and then you re-compare.
7. Agree. A few variables maybe at work
I agree with you on dunking money on a BBK for your MPV. I have been thinking of doing the same too but been too lazy to source.
The key argument here is the relative size of the common MPVs vs their stock brakes. The cars are big to begin with. When they are big, they are heavy plus not to mention the load they are meant to carry. Upgrading to a better brake definitely makes perfect sense though in local motoring scene, it’s far rarer than seeing bra-less gals walking along Orchard Road.
My advice is to those who are doubt bout upgrading brakes. You need to understand the need first and NOT a WANT. While function may take over form and vice versa, we can not duly criticize those who wish to make their cars aesthetically appealing. It’s your choice but you need to know what are the risks (if any) associated with that ( point 5 especially )
If your car has power upgrade, u need to simultaneously ensure the car can stop n time especially under heavy driving circumstances. The weight of your car plays a major role too. Some even said the stock GTR brakes aren’t good enough for the car when driven hard. Well, I am truly not surprised.
Ai Brake Mai?
Jack, good points as well. There are the guys that "need" them for track and there are those that "want" them for the looks.
OMAR
U may notice that there isnt a real duct of tube shape for the brake but did u realize that the front bumper on the side has two ducting holes? Those are for brake cooling.
E46 M3 had that.
To compare with E46 brakes on stock set up, the brakes fade miserably on heavy driving. 4 hot laps max on track. Been there done that. The M3CS (ZCP version in US rolled out in 2005 ) had CSL brakes and performed better.
With E92M3, I am sure the brakes are more capable now commensurate with the car's power and set up. But hey, I wouldnt push to 8 laps if I were you. At least I would hv installed a race pads before I do that. I cant afford to leave SIC for home w/o my balls with me.
Brake bias is harder to address given so many variables and the expensive BBK parts. Example of variables - front installation only, front rotor size decision, lower CG versus day-to-day comfort, wheelbase of car, weight distribution issues complicated by ICE, and even use of semi-slicks tyres. Each car has to go through the trial-and-error tuning for optimal brake balance based on the brakes selected.
if you have ridden a bike you will know that using the front brake alone will stop the bike in a shorter distance then using the rear brake. but using both will definitely stop even faster and shorter. therefore it is always better to upgrade all 4 rather than only to the front causing unusual wear and tear, and upsetting the balance as well.
+1. Then the relative rotor/caliper piston sizes will be the contention of argument......
