BMW Performance Intake & Exhaust for E90 320i?
detach8
ANy bros here tried the original BMW performance intake and exhaust for E90 320i LCI? Any feedback?
Re: BMW Performance Intake & Exhaust for E90 320i?
BMW performance intake is not meant for 320. You can try GruppeM.
Just saw that on someone's 3 series on this forum.........and it was on a 323.
for 320i, can consider Simota CF intake ... GruppeM alike
the below picture is from bro chershen awesome red :D
http://www.bmw-sg.com/forums/bazaar...0-wts-simota-cf-air-intake-318-320-lci-2.html
Hmm but the brochure says 320i... for the intake.
Edit: I pak jiao, its 330 not 320!!
Thanks for the suggestions! Will look around.
How about the exos?
where can i buy the intake ???? Thanks in advance
contact site sponsor BOSS Motorsport.
look for nic or calvin ... happy modding :D
You might also want to consider air scoops to complement the intake ..............
No bros here tried the exos?
Bassy sound, good mid ~ high end. Very willing to pull. Gives you a straight thru exhaust gains & having the semi thru advantages (for an auto rides)...
Only down side is you have to custom weld a (Lost) hanging point & torch it in order to have a perfect fit onto the rear bumper.
Happy modding ~~ :)
Happy modding ~~ :)
hmm? custom weld? bro are you talking about simota one or the BMW one? :p
tomace;643264 said:
Im refering to BMW peformance exhaust. :)
har how come have to custom weld, i thought it's a bolt-on plug-n-play silencer?
You can choose to plug & play but the exhaust tip will be pointing downwards.
Stock exhaust has 3 hanging points whereas Peformance exhaust only has 2. They didnt have the front left hand side. :)
Oh! Good info! I didn't know that!
So that pic in yr sig is the BMW exos I presume?
tomace;643453 said:
Yes .. ;)
Cheers ~~~ :)
Bro, I searched the other forums and I found one that said BMW recommends installing the silencers WITHOUT the springs, so I guess you installed it with the springs that's why it's hanging low?
I dont remember seeing any springs.. :thinking:
If you are talking bout the springs bots tat attached the mid pipe to e muffler, you needed tat as it will prevent leaks for the jointing parts.
Anyway for BMW performance exhaust, in order to have it approved & inspected by LTA, you have to get it done by PML (be it new ones or used ones) Down time 1 - 2days. :yummie:
For a used set, do make sure that it was purchase & installed / have it inspected by PML. They will not entertain those not purchase from them. :)
Happy modding ~~~ :)
