BMW 5 Series Thread
Juzz Performance
Trusted Sponsor
While our team was conducting the replacement of the heat exchanger & oil filter housing, we noticed a mild corrosion on the cylinder head as well as oil filter housing. Over time, the existing coolant deteriorate which heats up when the engine is running and caused this corrosion. This shows how important it is to regularly renew your coolant. Changing to a new complete oil filter housing (not just gasket) is necessary as the coolant flow line is warped and coolant may mix with engine oil, which will then cause further issues.
Hi, Im having the exact same issue, how did you solve the corrosion issue on the engine block? Did you sand it down or filled it up? I keep getting oil leaking into my coolant. Any tips is appreciated. Thanks.
BMW N20’s engine common issue: Broken chain guide.
The N20 engine is commonly found in the following models; 220i, 320i, 328i, 420i, 428i, 520i, 528i. When the chain guide breaks, you may encounter these issues:
1. Rough idling
2. Low engine oil pressure
3. Stalled engine
