Calvin West
Hi guys i understand the 125i is using a 3L N53 engine producing 220hp. If it is the exact same engine in the 630i 272hp, would be be possible to tune the 125i power up to 272hp?
Calvin West;1062361 said:Hi guys i understand the 125i is using a 3L N53 engine producing 220hp. If it is the exact same engine in the 630i 272hp, would be be possible to tune the 125i power up to 272hp?
Red_Bean_Bun;1062364 said:You referring to the n52 engine not n53 correct ?
ac323;1062363 said:630i could be N52B30?
cheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeers
ac323;1062365 said:think there are some with N53 3L block.........( not sure if it is used imported unit )
Red_Bean_Bun;1062367 said:Heard n53 got issues with high sulphur petrol ......
Bro, consider this basics. Tuning up NA* with big Hp/Nm figures (e.g. 220-to-272, a 52hp gain) is not as easy as FI* rides.Calvin West;1062361 said:Hi guys i understand the 125i is using a 3L N53 engine producing 220hp. If it is the exact same engine in the 630i 272hp, would be be possible to tune the 125i power up to 272hp?
It is still not just a simple tune up matter e.g. piggy bag or remapping. Internals still need consideration even if bore and stroke spec is the same.Red_Bean_Bun;1062377 said:The variants of the n52b30 bore and stroke specs is the same. So it was built for 272hp.
To de-tune it to 220 hp via the sw is what probably happened.
Baby1M;1062380 said:It is still not just a simple tune up matter e.g. piggy bag or remapping. Internals still need consideration even if bore and stroke spec is the same.
Just IMHO.
Red_Bean_Bun;1062406 said:Guess it could starts at 272 hp and it could step down to 265 or 220 hp ......
So if you could crack the dme sw codes then you could release some potential based on the assumption entire engine block is the same ......
Jason8822;1062430 said:If cracking the dme is so easy then there will not be so many N52B25 running around as 523, more than half will un-detune to 525 liao.
