snowman said:i dont think it expensive boring the trottle body to a bigger diameter right??? by the way, u know who can do it?? or who can assist in doing it??? TIA
quiksilver said:It depends on your threshold and definition of "EXPENSIVE".
For example, if to you, GruppeM is expensive compared to Simota, then Boring = GruppeM. u are better off looking for second hand ECU chips in the buy/sell forum, it might suit your budget more.
by the way, changing the displacement of your car this way is illegal cos u r cheating the govt of road tax...
wilman2772 said:Bro, U mabok ah??? Big bore throttle body not = to bigger displacement!!!
'Clan Master'
snowman said:but it can still be done right? dont really know much for conti car, but for jap car, the usual case will be remove the throttle body, send it to some professional to machine and bore the throttle body, they will also machine a new piece of butterfly so that it will be able to fit very nicely onto the throttle body. this matter is very commonly done on jap car.
Whisky_Tango said:Here's a link that mentioned valvetronic engine has no throttle body.
http://waw.wardsauto.com/ar/auto_new_bmw_engines
Here a pix of vlavetronic engine, the servo motor at the top controls the third camshaft. The Y-arms which at their base move the fulcrum of the rocker arms back and forth, varying its leverage. Thus varies the valves opening amount.
snowman said:huh? but i thot i saw it when the mechanic remove my air hose lei
piggyboyz said:Boring out the throttle body on our car is impossible, at least for Singapore mechanic.
The throttle body is electronically controlled, boring out the throttle body will require the throttle butterfly to be replaced with a bigger diameter, else there will be too much air leak. the throttle butterfly has got the connecting rod connected to a gear, which is in turn connected to a sealed electronic motor. u must be ready to strip the whole electronic before u can even think of boring out the throttle body.
For the 320, 325, easiest will be to get a 330 ones and do a bit of modification to the intake manifold.
TripleM said:Speaking from experience huh
