best spark plugs on this planet
ho2786
Banned.
hi bros
can some one please tell me what spark plugs are the best on this planet ?
ho
Re: best spark plugs on this planet
ho2786;153043 said:
hi bros
ho
Volker Spec II for me. Was on Spec I and thought they were good enough already but when I put in spec II...........Woah!!!!!!!!!!!!! Revs very well all the way to redline......gives you that Oomph!
You can get from UM2. Look for Cheng Poh.
poly65;153079 said:
Can you tell me where is UM2. Thanks.
Hi ! Bros.
You asked for it :)
UM2 Performance Tuning
Blk 4 Kranji Loop #01-20
Tel No 62691330
Simon
How long do these Volker Spec II spark plugs last? Do you need to do regapping?
i think OWS twin iridium spark plugs are the best on this planet.
cause they very expensive.
Mixmaster
My car is on the VR plugs Spec II
Do a search on this topic...I did some write up on this...
It's truly awesome and too bad, for your car, it will set u back almost 500 bucks...
Been on it for a yr I think and it's been consistent in performance and idling
TripleM;153131 said:
Mixmaster
triplem, may i ask if these VR spec2 will be suitable for N52 engine? need any ECU or plug adjustment? cos i heard wrong plugs will cause misfiring etc. thinking if getting it done at BVO.
Then go buy OWS Twin Iridium lor...............
500 singapore dollars for 6 spark plugs ?:yikess:
omg will they add another 10 hp to my car ?
i guess i will have to break my piggy bank again.
Mixmaster
Pak
Here is your write up - http://www.bmw-sg.com/forums/engine...s-vr-plugs-spec-ii.html?highlight=volker+spec
I reserved the last set of the VR plugs Spec II from UM liao. Just wanted to confirm that the feedback is good. Since you said that it is truly awesome, then it is a must mod item liao. Cos, when it comes to what to mod for M3, you da man. :)
OT a bit, I went down to check out your rims. Yup, they are in good condition.
Mixmaster
Thanks...guess they didnt wash for me unlike S.E tires shop..
U will notice that (with these plugs) when doing cold start in the morning, ur rpm won't be as high as before even tho your rev counter is still 4-5 bars. I love these plugs..
Price is the problem...too expensive but then again, it's limited production. No one in the US has it for your guide.
Pingman
10bhp is a lot for plugs....I think max probably 5bhp for the plugs...
