BBK rotor upgrade need help
tohallan
Hi All,
Thinking of upgrading my rotor size to a more common size of 328 x 32 mm rotors (from 322 x 32mm). And as such I will need to somewhat mod the brackets slightly in order to accommodate the new rotor size. Below shows the brackets. All I see that needs to be done is to have washers (3mm thick) placed at the radially mounted bolts (see arrowed) that would give me the additional clearance needed for the 6mm increase in diameter. Would I be on the right track. You inputs appreciated.
Thanks in advance.
Re: BBK rotor upgrade need help
Pardon me but adding the washer isnt going to help you. The washer should go on the other side of the caliper between the bracket. Correct me if im wrong
Hi
Thanks for your inputs. Looking from the inside of the wheels looking out:
Perhaps this wold be a better view where to put the washers. The arrowed are the places where the washers should go (I think). This would move the calipier towards the left hence giving more room for the new rotor size.
