Awhere to buy cheaper brake pads for E90 320i?
E90koh
Anyone can give recommendation? I intend to buy and pass them to PML for installation. Just to save some $$. :p
Re: Awhere to buy cheaper brake pads for E90 320i?
Why die die must go back to PML? Can get change in any of the site sponsor.
How much did you pay for your stock pads?
Go Eng soon buy lor..cfm cheaper then PML. If u want dirt cheap maybe Propel denis have a few sets from accident ones.:roll:
Accident ones? Haha. Mai lah. Got voodoo lei. Ok, I check out with Eng soon. Kam siah.
you better cehck with PML before you make any purchase of cheap item outside
and i doubt PML will be able to install for you those critical part purchased from outside for you especially they do carry the BMW approved part:dance:
PML is a responsible organisation approved by BMW:wavey:
Changed brake pads front and back for e90 320.
S$420, original textar pads.
With M& Q Autoworks, just yesterday.
For textar, it is strange to change both together. Rear pad will be replaced after every 2 set of front pad.
Bro.
Consider changing the entire F&R to E90/E92 325i Caliper & Rotor..Front rotor 330mm vs 292mm and rear is ventilated 300mm vs solid disc 296mm but need 17" rim..I am doing it now. Another bro here selling his E90 325i F&R Zimmerman cross-drilled rotor (almost new) with Calliper and new pads very cheaply...
You can pm mb1802003.
Wah bro, you really are a pro man.
Change brake pads also got skill?
FYI, it wasn't entirely worn, but i had them replace it anyway.
