Auto Air con - internal circulation
Ah Lian
Hi, my FL 320i (2months - basic model)
It is quite irritating to have to turn on the air-con interior-circulation switch (although one is on the steering) always forgot and reminded when foul fumes from other vehicles seems in.
Any one know how to auto-turn it on .... e.g. can I get PM to do a software - turn on? Or I am "doomed" to every time turn it on.
Next is the auto-down unlock "twice" for the passenger seats". Is there a way where I press the key once and it opens all 4 doors?
Re: Auto Air con - internal circulation
for the aircon, most likely you need to press the internal circulation each time.
one unclock = open 2 or open 4 doors. you can set with your remote control. use the SET function. check your manual. the setting is saved in your remote control. if you use another remote control, then you need to do the same setting.
i tink it can be programme bro...call pml to check ..cos i had the same problem but i remmember once it came back fm servicing it became auto on evertime i start the engine and before it was not.....
for the doors deftly can be set the way you want it to be.....
Hi Steven
It wasn't PML reprog..
If u set aircon to auto, it will stay auto. Otherwise, it's open vents by default everytime u start the baby, even if u'd set it to recircu when u last shut down. At least it's the case for me.
Thanks! Both of you great help!
Managed to find how to re-program the key-auto unlock once!
When I go for the next servicing at PM, will certainly ask them to try to set the circulation ON always...!
Great help! GUYS!!!!!
