Re: Anyone did free air subs on E46 rear parcel shelf?
Playtennis;489318 said:
Hi Bros,
I am considering a pair of free air sub on my E46 rear parcel shelf and hope the bros who have done so can share the following:
1) What was the model and size of the free air sub?
2) How was the quality of bass produced (in your personal opinion)
3) Who did the installation for you, how would you rate his workmanship?
I have gone to some audio shops and they kept insisting that boxed enclosures are better, refusing to explore further. Are free air subs that bad or they are not sure how to optimise the sound?
Kindly advise. Thanks.:thinking:
it depends on wat you like for subs: spl? or quality depth? if spl, forget abt free air.
else u can get most reputed 12" free air subs, or even good strong magnet subs.
if u dun like to cut a hole in your rear parcel, also forget abt free air. you need to cut a hole.
i had an E46FL sedan previously, and i installed a 12" with strong magnet subs, as i only wanted accurate depth, but didn want it to intrude too much into the boot opening. i used a veri slim pioneer TS-SW1241D (mounting depth 86mm). reliable and accurate bass, using a underdriven (lotsa headroom) 600W Alpine ClassD mono-amp. it is satisfactory given the little space the subs took out.
realistically, i did connect some good boxes to check and compare, and I still find that only the well designed bandpass boxes with several better known subs sounded better than the combi above. the combi i did above was reasonable.
now this is just my opinion, n i'm sure there are gurus out there who may disagree:
i actuali chose japanese made components due to their lower deterioration (due to our extremely hot & humid weather) as I used to use (and change every year or so) the better known subs (focals, dls, jbl, lotus, jl) and no doubt some were superior when first installed, but they didn stay that good for very long... deterioration is faster than the good japanese makes... so as i prefer install-once-and-forget nowadays due to other commitments, so chose to compromise a little fo initial quality, but long term wise, relatively good.
just my 2cents.
p.s. i use a 701 for sound processsing. i think this is a necessity in case of my choice of setup. unless u can find a very well tuneable mono-amp, which i dun have much knowledge of, as i believe they are also quite rare, do consider a good soundprocessor to help you get your upfront, well tuned and accurate bass.
