Any good paint workshop to recommed for headlight restoration ?
Algino
Dear all ,
Due to highly over utilisation on my e60 on NSH and now my headlight need some pamper work to celebrate this coming CNY , any gd work shop as mentioned to recommend ? Thx million
Re: Any good paint workshop to recommed for headlight restoration ?
Try using colgate to polish the headlight, might do the job.
Colgate works .... Darkie works too .... Use a hard rated toothbrush.
That's the first step if you wish to DIY. For those who dare, you can try my method which was a 3-step buffing/polishing with different grit sandpaper (those 'smooth' green felt types). I used this on my previous cars.
The next step is even more important - you need to get a good sealant to protect the plastic once the oxidized layer has been removed. That will protect the lenses and slow down the oxidisation after the restoration.
For best results, approach the experts which are our site sponsor workshops (eg. Revol, etc) which can be found in the site sponsor directory.
I use DA polisher + headlamp polishing compound, finishing with collinite 845 = 100% satisfaction. If you DIY make sure you are not burning your lamp cover by staying your polisher at same position for long time or else it will be chao ta.
No confident enough to do the DIY lei , my headlight are full with pitting and scratches and really need expert to sand + polish GAO GAO to make it work .. Did called revol but too bad they can't do it
You need to sand and polish your headlights definitely. You can head to Toh Guan theres on grooming shop who does for $60 or you can try Dr Glass(mobile service). I did mine with them for $80 bucks, excellent work i would say.
Bro , mind to pm me the contact ? Dr glass or the toh guan workshop name ? thx !
pm sentzzzzz
Today went to Autobac to buy something. They have head lights polish for $30 per pair. You may want to try it.
Their headlight polish service CMI... they only use a small bit of meguiar plastiX and buff your headlights to make them look "brighter". All done within 10mins, no sanding or application of headlight UV protector is involved.
On heavy oxidized headlamp polish, they need to wetsand by using #1000, #2000 and finishing with #3000 sandpaper, then follow by compound polishing and ultra fine polishing cream. Some shop skip those fussy procedure and just use #1000 sandpaper follow by polish and protection coating. End up the oxidized layer eliminated but some fine scratch is there and trap dirt and dust , when the time goes by, it will be worst than before. This kind of work need half day to complete.
Just share my own experience here, don't flame me like MCFers.
Have called dr glass and arrange for headlight restoration work tomolo . Let's see what dr glass can do in my serious case and will update the result then
Just make sure you ask what is the final protection coating they use. Some UV protection coat can't last long, if they use meguiars wax for final finishing , just slap them by your boots.
Bro, soundslike my cfo make up lay... uv protection... sun block... Lol
Hehe, no la, i accompanied my friend for his headlights polishing by a freelance which claim himself as best headlight polishing expert in local, end up i saw what he's doing is worst than a half pail full rookie like me. But lucky his price is damn cheap and he keep treat us ciggrates and mineral water till i don't want to slap him by my sandals. At last, i still had to help my friend to redo again.
It depends on owner expectation on the outcome.
How much and what is the address? Tks!
53 , ubi ave 1 #05-14 Singapore 408934
Saw them doing all good cars and price also reasonable.
vin55org
