V-Force
I am really confused and need advise and help. Well, to cut things short, my questions:
1) I have a extentsion cord using BS 1363 plug ( BS 1363 - Wikipedia, the free encyclopedia ) with fuse (13A) and I am wondering if I can change the plug to CEE7 st. sh 7 type ( Yung Li Co., Ltd - European approved power cords, plugs & connectors ) as I am using it in Indonesia? The plug (YP-22 from the website) I am changing it to does not have a fuse.
2) If I use a BS 1363 plug with fuse of 13A, do I still need a Power Stabilizer unit to prevent damage to my electrical items (eg. computer, laptap, TV, fridge etc) from instable electricity voltages?
3) May I know what is the precise use of the 13A fuse or even a 5A and 3A fuse? What does it prevent and is it really required?
4) My power stabilizer unit uses a 3A fuse, everytime the is power failure and when power comes back on again, the fuse blows. I did not overload the power. What is the likely cause of this?
I connect an extension cable using a YP-21 2 pin plug direct the the wall socket. A fan using 150w is connected to the extention cable and also my 500W Power stabilizer unit using the CEE7 st. sh 7 plug.
Connected to the Power Stabilizer unit is another extension cable using BS-1363 plug with fuse 13A. Then, on this extension cable, I connect my LCD TV, DVD player, Cable Box and Playstation. Total usage of watt is 180w for all the items.
Can someone please be kind enough to answer my queries, I thank you so much in advance.
V-Force
V-Force
