stevenwu;521737 said:hi bro,
Anyone ?
I tried for 2nd day now, on dry, traction not so good lei...![]()
stevenwu;522204 said:hi all,
Thanks.
went LS and he recommended RE001 so bought without doing research...
Knight;523641 said:Just finish off 2 pcs at rear within 9mths duration.Consider it,Good,Gripping in dry & wet. But tire wears off quite fast,should be due to this soft compound rubbers..(What I think) You need to run in the tyres..Then U can feel its performance..
crombie_sg;523556 said:Hi,
Been using it for the last 6 months. No complain and I think VFM.
I guessed a lot has to do with size and pressure.
Maybe you can check on these 2 items?
Normal commute I hit about 150km and still grippy...
stevenwu;523727 said:hi pal,
9 months is kind of fast to wear off the rear tyres.....care to share the distance they \ve been travelled ?
