Alternator for E90 320i
TohTo
My 2006 320i battery warning light up and disappeared intermittent. My WS said is alternator failing soon. My car mileage is 164k. Left only 2yrs+.
Any bros changed the alternator for their 320i? Care to share how much you spend so I used as a guide. Only local WS.
Re: Alternator for E90 320i
Hi bro,
We have original used one in good condition.
If you need please give us a call or can leave your contact number to get back to you.
QUOTE=TohTo;1058719]My 2006 320i battery warning light up and disappeared intermittent. My WS said is alternator failing soon. My car mileage is 164k. Left only 2yrs+.
Any bros changed the alternator for their 320i? Care to share how much you spend so I used as a guide. Only local WS.[/QUOTE]
Did the WS have the alternator load tested and also confirmed it's not the voltage regulator or battery ?
If voltage regulator uplorry, everything will shut down.
True when up lorry ...... But sometimes it half up lorry then voltage cannot regulate at 12v so end up the dash once in a while show error.
Cheaper than replacing entire alternator so no harm checking it out.
The charging voltage. Fluctuate from 12V+ to 14V+ at constant rpm. When the error pop up, the voltage is less than 10V.
BTW, I had replaced the alternator, so far no more error. Previously a 20mins drive the error will pop up 3-4 times.
