I had encountered this problem last Thursday. Cranked my car, drove off in SD mode (as usual), but as I left the carpark, Christmas lightings appeared on my instrumental cluster. All these indicators lit up - ASC, ABS, airbag, handbrake, canopy. Stopped the car, came out and check the capacitor - it reads 13+ volts. Xenon headlights were working fine. Drove off.
On the expressway, the power on the stereo was cut off, followed by the aircon - fan was still running, but no cold air coming in. Then the fear factor came about...... I could neither upshift nor downshift at expressway speed !!! Switch to paddleshift, it was reading M4 when I upshifted, M2 when I downshifted, but the gear was not changing. When I reached local traffic, the car moved off the traffic lights on THIRD gear. A small exclamation mark with a circle around it appeared between the letters S and D on the instrumental panel. Never seen that before.
Brought the car to BVO on Friday morning. Reached there, called for cab, then tried to crank again - dead !!! Lucky did not drive to work.
Diagnosis? Ah Wee said bad battery. Belt was changed after Christmas. Alternator working fine. Battery was changed (VARTA), reset my HU, peace after that. Boh tai ji liao......
Two questions lingered, assuming it was not the case of a faulty alternator:
(1) if the output is not flowing through, is it true that functions and gadgets dependent on electronics like gearshift (perhaps fuel throttle) cannot be overridden manually? That is a scary thought, but I really could not downshift....... Any impact on the ECU?
(2) the battery output did not taper off. It is more like cliff-drop on its last day. No sign of predicting it? Now, how else could we tell about a dying battery?
