aircon wind speed "no strength"
okl
Hi guys,
New to this forum, 2 days ago sent my 318i to kampong arang for oil servicing and engine misfired problem with some faulty parts replaced, total cost $1016.
And today i noticed the aircon fan speed "no strength" , and i have it switched off and on it back again later, it back to normal.
I dont know will it happen again...
any advise?
thanks
Re: aircon wind speed "no strength"
im thinking that i should go back to PML and make a complain after servicing they casused damage to the aircon.....:D
since the problem has gone away, it'll probably be a fruitless trip because the CSA can't replicate the problem. chances are, you'll even end up paying for the diagnostic test done instead...
hmmmmm........but im sure it will come back again since it happened once , from your experience...do u think so ? :) all these electronic things...cant be cured itself??
sounds like speed regulator. It may start to go fast and slow. Fortunately not that expensive, think replacement part is less than $100
yeah....have it replaced b4.....breakdown again??!!......here $100+ there $200+ again.......! :furious:
I know what you mean, but at least not 1k here, and 2 k there.
guess wat.......why so suai....my bimmer back got hit...the car was a jap car...front crushed...and my back only scratches and and dents....!!...im so busy with my car servicing and reparing?!? is car a burden.....
Re: aircon fan speed "no strength"
Also could be some resistor (or something like that). Cost $20 plus buck for the part but labour charges depends on the workshop. This part is located behind the glove compartment. Paid $50 plus GST for my ex FL 318 E46.
I have the same problem with the that car. Once in for fixes it never end there....
Good luck.
Dav
789wincareers
