Aircon Blower weak during long distance drive
franklkk
Hi, i came came back from Malaysia after a long distance drive to a few towns at Johore. The car is fantastic and I did not really encounter any problem during the drive. Especially when overtaking cars along the road leading to Mersing. It really effortless.
However, I have discovered after about half an hour continuous driving. My air-con blower started to get weaker and weaker. I then increase the speed of my air-con but the blower did not improve at all. But, luck that cold air still emit from the air-con vents.
Any bro here did come across the same or similar problem with the air-con blower? Am I right to say that my air-con compressor kaput liao.
Regards
Frankie
Re: Aircon Blower weak during long distance drive
if air coming out is cold, then aircon compressor is ok
the air coming out is not strong then its the blower problem
Nope that the air-con compressor is ok. Then, anyone know what is the possible reason that causes the blower faulty? Isn't expensive to rectify the fault?
It happened to my friend's Chevy, the cooling fins got frozen because the thermostat doesn't cut off the compressor when the desired temperature was reached.
Your case may be different but this is something that happened for my friend. After they change out the thermostat ( the red/blue dial ), all is fine.
In this case. I think I better send my car for a check. Hope & pray hard is not the fault of my air-con compressor. If not, I have to ask propel for help liao. :|
