Air vents on middle of dash-board
Ah Lian
1. Strong air flow - air vents
Often I got fogging on my front windows due to the strong air flow coming from the two air slots on the middle of the dash board!
I was thinking of placing some mat to cover these vents? Any advice? is this OK?
Or can I get PML to shut down or reduce the air-flow, here, Possible?
The other thing is that I still have streaks on my front windows.. can I use asoprol alchol to clean the exterior window.. sorry I don't think I spelt asoprol correctly it is actually mentalated spirit or something like that.
Thanks! for your advice!
Re: Air vents on middle of dash-board
try hitting the "AUTO" button around the aircon controls area, it should regulate airflow and help avoid misting.
Hi Ah Lian,
You can never get rid of the streaks permanently.
I too was puzzled after cleaning the front windscreen
of all my cars b4, the streaks comes back every so
often, this is due to the dirt & grime, oil, bird crap, bug
innards and what have you that are out there on the
road, they are all attracted to the just cleaned spanking
clear windscreen that we have so religiously wiped.
So there you have it, I accept defeat & execrate & wipe
every other dirty day.
Are these streaks on the path of the wipers' sweep area, or just outside their extreme positions?
If it's the latter, might be the hard water in our water supply which leaves deposits.
Have you tried using diluted vinegar to clear it?
