Air-con problem
T6
Guys,
Need some advice here. In the past week, there were 2 instances when my air-con fan suddenly stopped as I was driving. After mebbe 5 minutes, the fan will come back on. I am not sure if it is a sign that some part is gonna spoil soon. Any idea what is the fault and can anyone recommend a good workshop that can trouble-shoot BMW air-con problems?
Since the problem only occurred twice, I am also concerned that the problem cannot be replicated when I go to the workshop at this juncture, then it is a wasted trip, or worse still, the workshop then ask me to change all the unnecessary stuff it dunno the problem.
Any advice is much appreciated. Kum xia.
Re: Air-con problem
Andy,
u look for Ah Chuan @ 96604911. He knows E39 well and does the aircon repair or replace with reasonable price. Look for him and check what's wrong first.
Moto-Aire Service Centre
Blk & Sin Ming Road
#01-88 S575642
Voice" 6451702
Re: Air-con problem
You mean the engine fan? Happened to my E46 before, and eventually it became more frequent and almost ended up with an overheated engine. Changed the faulty fan, everything back to normal again. :)
Re: Air-con problem
Thanks. Earnest of BVO said might be some resistor problem which is a cheap fix. He also suggested I blast the air-con at full speed first in case some dirt caused the fan to mul-function. I will monitor. Kum xia.
Re: Air-con problem
confirmed resistor problem...oen fine day the resistor will resist no more and kaput...get it changed soon
Re: Air-con problem
Just curious: if it's really resistor problem, then is it something that can wait until the thing dies then change, or is it something that you better do something now or else it will lead to something else more major?
Re: Air-con problem
so far when it goes off...gets damn bloody hot when u drive i tellu...and uncomfy....dunno abt other problems but heck, get it changed ASAP
Re: Air-con problem
Yup, it's the resistor pack that's gone kaput. I encountered the same problem myself, started off with the air-conditioner blowing at the same speed regardless of where the dial was, therefater, blower went dead and the only way to get it moving was to set it to full blast then bring it down to the desired level.
