Air-con compressor - replace - E90
Aaron_BMW
Hi guys,
Just to share the replacement of the air-con compressor.
1st, it's not damn expensive to replace
2nd, it's considered a maintenance part of wear and tear. Usually breaks down every 3-5 years with daily usage.
3rd, down time is only 2 hours
How it happened?
Just suddenly not cold one day,
What should u suspect when air-con is not cold???
1. Usually cooling coil leaking air-con gas
2. Air-con compressor
"Note" - usually is either or breaks down and not both together.
What are the main components of the air-con system? (For ur knowledge)
Compressor
Condenser
Cooling coil
Drier
Expansion valve
Heater coil
Heater valve
For my case, this time the air-con compressor is down and simply just replace it.
If u suspect cooling coil leak has, see below:
For cooling coil related repairs and hot air problem, see the topic on air-con recovery http://www.bmw-sg.com/forums/showpost.php?p=981756
What should u do if u need to ask me for contacts and parts???
Please please PM me
Cheers~!!!!!!
Re: Air-con compressor - replace - E90
Hi Aaron, how much is the part cost? Nice and shiny looking oem bmw compressor.
Seems like you spend a lot on maintenance for your car :lol:
Different shops selling range from $550 to $640 +/-
Hai..... Yes. U r right !!!
But I know I am a heavy user for my car. So no choice. Take care of car so car takes care of u
Thanks Aaron, you change to the rotary type?
I don't know what is the rotary type.
I change back to the same compressor as before
Bmw has high wear n tear. Just change my alternator , engine n tranny mount and rear brake rotors n pads. Total damage $1200. Mine e60 523.
Greetings Aaron,
Compressor can be piston type or rotary engine type. Yours look round hence I asked if it's a rotary compressor.
I remember changing compressor of my old E60 and the original supposed to be a piston type which look tall.
Regards.
lf37;1047650 said:
Greetings Aaron,
Regards.
Thanks for the info!
I believe we are using different types of compressor
Hi Aaron,
Can pm me the price of the compressor n labour cost? Thx
xu4000;1057881 said:
BTW can you tell me where did u guys buy the spare parts?
U can get parts from stockies or directly from workshops
