Advice Needed
dewdropdawn
Hi guys, I'm new to the E90, YOM2011. And would like to gather some feedback and comments on the following:
Blackvue f/b with screen 24hr recording
And dealer says no need to install additional battery.
Looking forward to hearing from all.
Thanks for reading. Cheers.
Hi dew,
yes no need to add-on battery you just need a magic box.....
goggle Soundwerkz..
Hi dew,
goggle Soundwerkz..
Hi Sir, thanks.
I've googled soundwerkz, but kinda blur about it. And by magic box you mean??
Thanks.
Hi Sir, thanks.
Thanks.
it is a device..
Soundwerkz will be able to enlighten you..
it is a device..
Hi Sir,
Thanks for pointing me in the right direction. I'll call them later and check.
Looking forward to meeting up with you guys soon.
Cheers.
You will need to tap on the right constant supply if not your will kenna the "High rate of discharge" error. Normally if done right they should be tapping your alarm system power.
You will need to tap on the right constant 24V supply if not your will kenna the "High rate of discharge" error. Normally if done right they should be tapping your alarm system power.
Hi Sir, thank you for the above. I'll take note of it when I install the devices. Thanks. dew
