Am thkg to lower my ride but not wantg to spend too much changing the entire suspension as i thk the 335 already fitted wif the msport suspension. any advice on replacing to BMW performance spring or others alternative to recommend??
hi chongster, can get both anot ah.... hee hee... ai p ai qi....heehee
after havg the performance bodykit, felt that the look wil look sharper if the car is also lowered.... so want to hav the look but also not compromise to the original handling. any suggestion?:laughlik:
Hi R335,
I am not an expert on suspension nor do I drive a 335, but I am also a "ai p ai qi" robot and I have thought of this question for a long time. I think if you want to lower your car and yet does not end up with something that compromise / handles worse than your msports suspension, go for a good set of coilovers.....just my 2cents.
thnxs to all the recomendation, 1 question is when we r talkg about 'comfort', i assume it shd b softer type biased??
Any probm wif weight of rear 3 passengers and cos rubbing?? for info, i hav my fender rolled after changg to 265/35/19 rear
once you changed to coilovers, you will lose a bit of comfort but some of them has a good trade off between performance and comfort. I was thinking along the same line as you when i thought the m-sports suspension is too soft (too floaty to my taste).
From my extensive research a yr ago, the best ones (and not too overkill) are the AST Suspension + Swift Springs and the set of Moton that i have. I believe that there are still a number on the AST setup so you can try looking for them to have a ride in. If you wish to test the Moton, i can try arranging for you (but no promises).
Since you have rolled your fenders, there should not be any issue of rubbing.
