Advice needed for E92 100k mileage Maintenance
Zak
Hi Forum Friends,
What are the maintenance parts/services do I need for the 100k mileage maintenance?
Not planning to do it at PML.
And also would appreciate if you can pm me good and reliable workshop that can do the above.
Many Thanks :D
Re: Advice needed for E92 100k mileage Maintenance
Hello bro
I havent hit 100K yet but personally, I would go to one or two of the site sponsor workshops to seek their opinions. In terms of what to replace, let them advice you accordingly but best seek different opinions.
After that, you could either let them help you fix the problems (buy the parts from them) or you could always head over to the Stockist to get the necessary parts and bring them to the workshop.
hope this helps...
btw, what r u driving? e92, 320? 325? 335? M e92?
kevinbmw;1057987 said:
Hello bro
hope this helps...
nabey, ur advice like no advice leh
Thats the whole point...confuse people and then make people think I really gave advice. Sart...
Zak;1057942 said:
Hi Forum Friends,
Many Thanks :D
If this were your b&b Jap car, basic 100k major servicing should be looking out for wear & tear on serpentine belt, tensioner, water pump, thermostat, coolant hoses, engine & transmission mounts, wheel bearings, CV boots, spark plugs, valve cover gasket, shocks, brake rotors. (Not mentioning the regular service items)
Given this is a bimmer in addition you would be worried ... I mean concerned about the integrity of the numerous other oil and fluid seals & hoses as extensively discussed here e.g. oil sump, valvetronic motor, engine valve, vacuum pump, crank case, ATF sump, power steering hose, coolant hoses & the list goes on ... Everyone here has his own story, for my ride the previous owner had already changed the radiator, all cooolant hoses & crankcase oil seal, in addition I have had to change all 4 shocks, rear rotors, vacuum pump, power steering high pressure hose and VC gasket and preventive change of water pump, thermostat, fuel filter.
Get a reliable workshop to do a detailed inspection, problem is that some places are hard to inspect unless you take parts out - thats how they discovered the leaking high pressure power steering hose when they were changing the water pump-thermostat - so be prepared to discover new problems even as you are attempting to rectify old ones! The other issue is to what extent do you do preventive replacement vs wait till it fail? Looking back, I think I should have preventatively replaced the valvetronic motor oil seal when replacing the VC gasket.
Another confusing but yet look like gave good advice post. Sart...
easy;1058048 said:
so be prepared to discover new problems even as you are attempting to rectify old ones!\
This sounds so familiar.........
Keeping it top TOP nearly 8 years
Oil leaks are mainly below
I change at the following km for 6 cylinder inline n52 non turbo 2.5
No leaks, no oil disappearing
Oil missing Culprits are
Oil filter housing area gaskets - every 50,000km
Valve cover gaskets every 60,000km
Pcv valve leak (built-in)valve cover - 60,000km
Oil sump gasket leak - 80,000km
Valve stem seal - every 120,000km soon
Rear crank seal - every 80,000km
Front crank seal - every 100,000km
Other changes most done for preventive purpose nainly & some planned for later
Alternator 60,000km but did not fail
Starter motor - 50,000km but did not fail
Idler pulley and tensioner & belt - 50,000km
Brakes pads at 40,000km
Radiator small leak 80,000km
Expansion tank exploded - 80,000km
Oxygen sensors - 70,000km for smoother
Atf cooler 80,000km but did not fail
Atf fluids every 40,000km for Long life
Gearbox trans seal sleeve & adapter60,000km
Oil change every 7,000km
Spark plugs and coils - 50,000km
Fuel pump & filter regulator -100,000km plan
Brake Rotors - 70,009km
Struts - 60,000km but did not fail but did not fail
Differential oil change 40,000km
Front wheel bearing - 70,000km but did not fail
Add M3 Control arms - 50,000km
Guibo - 70,000km but did not fail
Center shaft bearing - 70,000km but did not fail
Engine and transmission mount - 50,000
disa motors - 80,000 but did not fail preventi
Aircon compressor - 100,000km planned
Aircon Blower 80,000km but did not fail
Water pump and thermostat and hoses 80,000km done preventive. but did not fail Yet
Sensors changed preventive but none had failed
Maf sensor - 80,000km
Map sensor (pressure) - 70,000km
Crankshaft sensor - 70,000km
Camshaft sensor - 60,000km
Eccentric shaft sensor - 40,000km
2 Vanos solenoids - 50,000km
Temperature sensor - 70,000km
4 Oxygen sensors - 70,000km
Oil pressure sensor - 80,000km
Timing chain tensioner - 80,000km
Wheel speed sensor - 60,000km
f8bett3gg
