futron.sim
I read on the net that some people have claimed that adding 2T (2 stroke oil) to their petrol tank in very small quantities (~0.08% or 8ml for every 10L petrol) can improve engine power. Don't know if its true but sounds interesting.
After doing some research online, I found that what 2T does to engine may be very similar to what petrol additives does.
1. Detergents to clean combustion chamber and exhaust. 2T engines are inefficient by design and it does acculumates alot more carbon deposits compared to 4T engines. Similar to what our petrol additives does.
2. Lubricate engine combustion chambers and pistons. I read from various premium grade petrol (eg. V POwer, Esso 98 etc) that it contains friction enhancers to lubricate piston rings and valves etc. This is pretty much what the 2T oil does as well.
Since its in very tiny amounts, I don't see how it can damage our engines or fuel lines etc. 2T engines works in the same way as 4T engines. It uses the same petrol, require fuel/air mixture to burn and has a spark plug. Made of similar materials as well (pistons, rings engine block etc). Our engines uses injectors and some 2T engines uses injectors as well (some are carbs).
Btw, 2T oil contains PolyIsoButylene. Its used as an additive and detergent in petrol and diesel.
