Absolutetint Platinum
cooldaddy
Hi anyone had the above on Windscreen?
I just installed not long ago. This supposed to be the best one among their other series.
Can I check with those who have this installed.. . do u still feel the heat??
My dashboard is still burning / baking HOT when the sun is out. I thought the Platinum series fr Absolutetint is supposed to reject 90% heat.
Pls help share your experience. Felt cheated as I was expecting my Dashboard will not be burning HOT when I touch it.
Sent from my SM-A800F using Tapatalk
Unless the film is opaque, else if u parked under the hot sun, no film can block the sunlight. It may block UV rays though.
Sent from the local post office
"Burning Hot" can be quite subjective (your feel and mine can be diff). Assuming when you put your hand on the dashboard and you feel it is "burning" your hand then that's quite bad. For my tinted windscreen, I still can feel the heat on the dashboard but not to the extend of hurting my hand.
