Able to add shift paddles to a E92 sports steering?
chicane
Will be getting myself a E92 sports steering to be fixed into my E90 320i. Is it possible to add the shift paddles separately so they come together with the steering itself?
Thanks in advance!
Re: Able to add shift paddles to a E92 sports steering?
yes that can be done.
take note is diff air bag......
u need to change ur air bag too
Oh, the answer that I dread. Where to get it done? Tks!
Thanks, I got the whole steering lock stock and barrel with airbag!
can be done at most recommended workshops here.
suggest u get from wilson and he will advise u where to get it installed. likely to be BOSS motorsports.
Chicane, are there two holes behind the E92 sports steering for the paddles shifter?
yeah....if no holes behind.......ley chey
look for mike at SWC. terry says one
there shld be holes. thats how the airbag is dislodge from the wheel.
are we talking about the same hole?
i guess not.....
mai OT ppl thread la. ppl serious about knowing how to install paddle's
u wan play hole next meetup i play with u k?
Slater;506601 said:
i guess not.....
i am serious.
he needs 2 holes at the back. if it comes with it, then just need to get the paddles and fix it in. easy
if no holes.... then only SWC can do it......
funny, we talked about holes, ho come c3po not in here yet? unless he busy with iscoupe real holes
hitmee;506605 said:
i am serious.
mostly likely ur assumption is correct. the 2 of them very quiet today. too good to be coincidental.
hitmee;506605 said:
i am serious.
Haven't got the steering yet, will check for holes the first thing I get them!
dun get too bothered bout it. no biggy
There are two type of Sports Steering for E90/92 - one for 335i (one already with Paddle-shift and has two slots/holes behind the steering that fit the paddle-shifter) and another just a normal steering without paddle-shift (hence no holes/slots).
If you're getting the sport steering already with two slots behind, then you will need the harness and buy the paddle-shifter separately. There are two type of paddle-shifter - the original 335i type (push and pull) and the M3 type (both pull - with + and - sign). Yes, BOSS can do the installation for you.
Guess hitmee knows which hole that he is talking...haha :lol:..
the top two hole masters (robot and iscoupe) not in so i take over for the day.
Bingo!!
Correct answer!
Well explained!!
Best to buy a E92 335 SMG steering wheel.
Cutting holes totally not advisable......can look dam ugly/messy.....paddles might not sit flush into steering also.
'The Great White'
chicane bought steering wheel liao leh. only option is to drill holes.
i have a e92 paddles steering wheel in my boot. but no paddles......
Ok, steering was from a e92 325 so i am quite sure no holes. So be it lah, already spend a bomb getting the steering, no holes also good. Thanks to everyone for their advice! BMW.sg wan sui! :)
